Displays the contents of the IP multicast routing table or the route origin priority.
source-net | Specifies an IP address/mask length. |
mask-len | Mask length for the IP multicast source's subnet. Range is 1–32. |
mask | Specifies a subnet mask. |
summary | Displays the statistics of multicast static routes. |
vr-name | Specifies the virtual router to which the route is added. |
vr-name is the VR of the current CLI context.
This command allows you to view the configured multicast static routes. You can specify the filtering criteria on this command to view only the desired route. The multicast static routes are displayed in ascending order of their prefix (same order as show iproute displays).
The following example shows a multicast static route from a default virtual router:
# show ipmroute Destination Gateway Mtr Flags Protocol VLAN Default Route 20.20.20.1 255 UG None pc4-1 *1.1.0.0/16 20.20.20.1 10 UG bgp pc4-1 *11.0.0.0/8 30.30.30.1 12 U- None pc5-3 11.22.0.0/16 20.20.20.1 10 UG None pc4-1 *11.22.33.0/24 30.30.30.1 8 U- None pc5-3 11.22.33.44/32 20.20.20.1 4 UG None pc4-1 *12.0.0.0/8 20.20.20.1 0 UG None pc4-1 12.24.0.0/16 30.30.30.1 0 U- None pc5-3 *12.24.48.96/32 30.30.30.1 2 U- ospf-extern1 pc5-3 44.66.0.0/16 30.30.30.1 0 U- None pc5-3 Flags: (*) Active, (G) Gateway, (U) Up Mask distribution: 1 default routes 2 routes at length 8 4 routes at length 16 1 routes at length 24 2 routes at length 32 Total number of multicast static routes = 10
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
